Old 31st July 2014, 03:50 PM
matheandcreate Offline
linuxubuntufirefox
Re: Video format/easy/worldwide
Second question:
Can Fedora convert videos to slowvideo or fastvideo.
Thank You.
Old 31st July 2014, 08:43 PM
flyingfsck Offline
macoschrome
Short answer:
Yes.
Medium answer:
You can probably do it with VLC, kdenlive, blender, or innumerable other video ediitors.
Long answer:
Read the ffmpeg help file. Everything you never wanted to know about video is in there.
https://www.ffmpeg.org/general.html
Old 6th August 2014, 06:24 PM
sea Offline
"Shells" (of a sub world)
MPG should be easy sendable too, as MPG AFAIK is just the abrevihation of MPEG, or am i mistaken?
Anyway, since that is a regular dvd format, it should be easy playable on any Windows version with mplayer.exe.
A bit inspired by this thread, and the task to reduce the space required by my videos on the nas, i wrote that handler script for ffmpeg: Video Handler Script
Also in addition of helpfull websites, these two helped me too:
Hope it helps
@ MatheAndCreate: What do you mean by fastvideo?
If you refer to faststart, with ffmpeg that is done by appending: -movflags faststart
EFI Cheatsheet :: http://forums.fedoraforum.org/showthread.php?t=298546
Video Handler Script (VHS) (mass re-encode videos, screenrecorder, console music/webradio player, ...) :: http://forums.fedoraforum.org/showthread.php?t=299182
Windows 8+ & Fedora 20+ Dualboot :: http://forums.fedoraforum.org/showthread.php?t=298161
Old 11th March 2015, 12:07 AM
patton517 Offline
macoschrome
MP4 seems the best solution if your friends not that geek.
Old 14th March 2015, 01:03 PM
linuxubuntufirefox
Hope it helps
Thank You.
MPG sounds good.
Its old, isnt it?
Are ther many MPGs or one MPG because there are many "Avis".
MP4 is new, isnt it?
I ll read Your links.
Thank You.
Old 14th March 2015, 02:35 PM
smr54 Offline
ffmpeg -i myvideo.whatever myvideo.mp4 will almost always produce something working.
If you get errors it may be (though this might just be on CentOS-6.x which has older versions) fixable by doing
ffmpe -i myvideo.whatever -acodec aac -strict -2 myvideo.mp4
(aac is a common audio codec but some versions of ffmpeg need that -strict -2)
For an overly detailed, rambling treatment about multimedia, I have a page at http://www.srobb.net/dvds.html (which has a link to a post on daemonforums by user Oko, which has a really quick guide to encoding video.)
Old 14th March 2015, 02:56 PM
flyingdutchman Online
macoschrome
MPEG2 should work even on a stone age abacus...
Have fun!
http://www.aeronetworks.ca
Old 26th December 2015, 12:46 PM
linuxubuntuchrome
MPEG2 is the container.
Isnt it?
But how are the files?
When I convert with ffmpeg I can see blackwhite chaos but no movie.
Does anybody know a workshop for ffmpeg like this one for videos:
http://srobb.net/dvds.html
Thank You. Regards
Old 28th December 2015, 02:56 AM
sea Offline
No, MPEG2 is a format, not just a container.
You cant use any other format in the mpeg2 container, only mpeg2.
Yes MP4 is new, and is a container as well as format.
However, this container can contain other formats (but not mpeg2).
MP4 does compress the data, mpeg2 does not.
hth
video
video problem in fedora 13 kde, no video format does work jibosillo Using Fedora 2 11th June 2010 06:58 AM
which video format is best for megaupload.com? kitharass Using Fedora 0 31st December 2009 12:46 AM
video format problem prudhviy Using Fedora 0 11th September 2007 06:54 PM
nice easy way to download online video google youtube sdowney717 Using Fedora 3 10th April 2007 04:13 AM
Easy way to format hard drives Fear Using Fedora 10 6th June 2005 03:12 AM
Current GMT-time: 09:44 (Saturday, 25-03-2017)
