  #31
Old 16th December 2016, 01:34 PM
hvniekerk Offline
Re: F25: nVidia M2000M kmod driver
Another look at Xorg.0.log show this:
(II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 6.524] (II) intel: Driver for Intel(R) HD Graphics: 2000-6000
[ 6.524] (II) intel: Driver for Intel(R) Iris(TM) Graphics: 5100, 6100
[ 6.524] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics: 5200, 6200, P6300
Although the i915 is generally used to indicate HD Graphics, https://en.wikipedia.org/wiki/Direct...rdware_support doesn't show the HD 530.
Since I'm using the HD Graphics 530, it looks like it's not supported.
Old 16th December 2016, 01:53 PM
meine Offline
with Fedora 25 MATE/i3 I completely removed the nVidia stuff and use the default nouveau driver because I couldn't find the nVidia drivers that fitted with the update.
the default configuration without nVidia works very well! nouveau improved a lot in the past years. no more flickering or distorted screens.
complexity is the origin of frustration, maybe you should give nouveau a try...
uninstall nVidia is described on various sites, double check to do all changes.
https://rpmfusion.org/Howto/nVidia
https://www.if-not-true-then-false.c...vidia-guide/3/
Fedora 25 -- i3, MATE
Old 16th December 2016, 02:18 PM
hvniekerk Offline
linuxubuntufirefox
Thanks for you reaction.
I'm not sure if you've read through the whole thread, but right now nVidia is not installed. And right now I'm baffled. Editing grub, I removed nomodeset once again, and find that the display goes to full HD for the first time. However, after login, the normal screen doesn't appear quickly but something still seems to be loading. But I suspect this is probably due to the HD530 graphics not being supported.
Old 16th December 2016, 03:30 PM
nobody Offline
windows_98_nt_2000chrome
Question Re: F25: nVidia M2000M kmod driver
Should be supported (even by generic i915) more then a year ago:
http://www.phoronix.com/scan.php?pag...l-hd-530&num=1
_nobody_
I am nobody, and nobody is perfect, therefore I am perfect!
Old 16th December 2016, 04:58 PM
hvniekerk Offline
linuxubuntufirefox
_nobody_
I found and read that link as well. So I really don't know anymore. I added the Intel config in xorg-conf.d again, which caused graphics to crash again. Removing it, and graphics comes again. So whatever is happening...
Old 16th December 2016, 05:56 PM
hvniekerk Offline
linuxubuntufirefox
The "no response" after HD boot is caused by "bug: soft lockup - cpu#0 stuck for (xx)s!" Some remedies I still have to test, and after the reinstallation I seem to have lost my entry to the BIOS/UEFI.
Old 16th December 2016, 06:52 PM
nobody Offline
https://bugzilla.redhat.com/show_bug.cgi?id=1355851
Related: https://bugzilla.redhat.com/show_bug.cgi?id=1354129
Related: https://bugzilla.redhat.com/show_bug.cgi?id=1397864
Please, read very carefully all three Bugzillas.
Point on:
Simon Reber 2016-07-12 14:06:07 EDT
When installing intel-gpu-tools and running intel_gpu_top it works and the flickering stops
From my Fedora 25 VM (CLI transcript follows):
[root@localhost ~]# dnf install intel-gpu-tools
Last metadata expiration check: 1:02:50 ago on Fri Dec 16 17:40:26 2016.
Dependencies resolved.
Package Arch Version Repository Size
Installing:
intel-gpu-tools x86_64 2.99.917-26.20160929.fc25 fedora 603 k
Transaction Summary
Install 1 Package
Total download size: 603 k
Installed size: 4.2 M
Is this ok [y/N]: n
Operation aborted.
[root@localhost ~]# dnf install xorg-x11-drv-intel
Last metadata expiration check: 1:04:30 ago on Fri Dec 16 17:40:26 2016.
Package xorg-x11-drv-intel-2.99.917-26.20160929.fc25.x86_64 is already installed, skipping.
Nothing to do.
Complete!
[root@localhost ~]# lspci -k | grep -A3 VGA
00:0f.0 VGA compatible controller: VMware SVGA II Adapter
Subsystem: VMware SVGA II Adapter
Kernel driver in use: vmwgfx
Kernel modules: vmwgfx
00:10.0 SCSI storage controller: LSI Logic / Symbios Logic 53c1030 PCI-X Fusion-MPT Dual Ultra320 SCSI (rev 01)
[root@localhost ~]#
I am on VMWorkstation, so I have Virtual GFX driver, which in-fact says nothing about the underlying HW used. But others commands can/might help you... I hope!
_nobody_
Old 16th December 2016, 08:13 PM
hvniekerk Offline
Results:
Installing intel-gpu-tools went fine. Then:
$ intel_gpu_top
Test assertion failure function intel_mmio_use_pci_bar, file intel_mmio.c:145:
Failed assertion: !(error != 0)
Last errno: 13, Permission denied
Couldn't map MMIO region
[huub@Klerksdorp ~]$ sudo intel_gpu_top
[sudo] password for huub:
Last errno: 1, Operation not permitted
So new options to be found...
Old 21st December 2016, 09:07 AM
nobody Offline
Hello there,
I did not pay attention to dracut, and the initrd.img creation. Never pay attention to such a thing since I always naively thought that these things are not changing at all, they are initially set as is, and carved in stone.
The purpose of dracut environment and its scripts is to make temporal initrd.img, and to mount the real hard drive (HDD/SSD) with the real / (root) system on it.
I failed in my thinking, which is nothing unusual, with the regards that many data and use cases are passing through my head. And... There are different requirements for embedded Linux, as for laptops/notebooks/DTs/WSs.
In this lieu, here is possible solution to your problem. In the steps of executions:
[1] Please, read http://www.forums.fedoraforum.org/sh...d.php?t=308108
[2] Then, please, read http://www.forums.fedoraforum.org/sh...5&postcount=12
[3] You should do exactly what finiteloop here advertises - add a nvidia.conf file in /etc/dracut.conf.d folder with the following context (one line of script): omit_drivers+="nvidia"
[4] Patiently wait for latest kernel to be released: kernel-4.8.15-300.fc25 and see if new initrd.img sans/without nvidia driver in it will solve your problem?
[5] Eventually, you will need in the new circumstances to rebuild Nvidia driver using DKMS!
Here is info about the latest kernel in testing: https://bodhi.fedoraproject.org/upda...ackages=kernel
_nobody_
Old 21st December 2016, 08:16 PM
hvniekerk Offline
linuxubuntufirefox
Hello there,
Nope. With kernel change, initrd.img sure gets recreated.
I'm not sure laptops and desktops differ. Sure they have slightly different hw, but they're not as different as embedded linux.
So go back to rpmfusion? I'm currently considering trying xfce, but just installing the meta-package. Gnome is no option: the Live boot failed completely on graphics.
Old 22nd December 2016, 05:35 AM
nobody Offline
Here, I tried to stress that one can recreate different initrd.img with different pieces/drivers. I always thought that initrd.img gets recreated on some static schema. It is obvious that (from /boot) every time new kernel is inserted, new initrd.img must be recreated.
I wanted to show differences between mobile category and embedded category. Never mind... Not thread about that.
DT GFX has nothing to do with your Nvidia problem. Use any, whatever you like. Dracut has to do a lot.
_nobody_
Old 22nd December 2016, 09:06 PM
hvniekerk Offline
linuxubuntufirefox
I've added the nvidia.conf and will wait for 4.8.15 as well as the Intel driver. Whichever works, works.
Old 24th December 2016, 07:01 AM
nobody Offline
Thumbs up Re: F25: nVidia M2000M kmod driver
Here it is: I just upgraded it!
[root@localhost ~]# dnf upgrade --refresh
RPM Fusion for Fedora 25 - Free - Updates                                    232 kB/s | 185 kB     00:00
Copr repo for radare2 owned by bob131                                         17 kB/s |  16 kB     00:00
RPM Fusion for Fedora 25 - Free                                              2.1 MB/s | 515 kB     00:00
google-chrome        53 kB/s | 3.7 kB     00:00
RPM Fusion for Fedora 25 - Nonfree                                           884 kB/s | 144 kB     00:00
RPM Fusion for Fedora 25 - Nonfree - Updates                                  86 kB/s |  17 kB     00:00
Fedora 25 - x86_64 - Updates                                                 3.0 MB/s |  13 MB     00:04
Fedora 25 - x86_64                                                           5.7 MB/s |  50 MB     00:08
Last metadata expiration check: 0:00:23 ago on Sat Dec 24 05:21:58 2016.
Installing:
 kernel                                x86_64            4.8.15-300.fc25            updates             92 k
 kernel-core                           x86_64            4.8.15-300.fc25            updates             20 M
 kernel-debug                          x86_64            4.8.15-300.fc25            updates             92 k
 kernel-debug-core                     x86_64            4.8.15-300.fc25            updates             21 M
 kernel-debug-devel                    x86_64            4.8.15-300.fc25            updates             11 M
 kernel-debug-modules                  x86_64            4.8.15-300.fc25            updates             23 M
 kernel-debug-modules-extra            x86_64            4.8.15-300.fc25            updates            2.3 M
 kernel-devel                          x86_64            4.8.15-300.fc25            updates             11 M
 kernel-modules                        x86_64            4.8.15-300.fc25            updates             22 M
Upgrading:
 kernel-headers                        x86_64            4.8.15-300.fc25            updates            1.1 M
Transaction Summary
Install  9 Packages
Upgrade  1 Package
Total download size: 111 M
Is this ok [y/N]: y
Downloading Packages:
(1/10): kernel-4.8.15-300.fc25.x86_64.rpm                                    471 kB/s |  92 kB     00:00
(2/10): kernel-debug-4.8.15-300.fc25.x86_64.rpm                              316 kB/s |  92 kB     00:00
(3/10): kernel-core-4.8.15-300.fc25.x86_64.rpm                               2.6 MB/s |  20 MB     00:07
(4/10): kernel-modules-4.8.15-300.fc25.x86_64.rpm                            1.5 MB/s |  22 MB     00:14
(5/10): kernel-debug-modules-4.8.15-300.fc25.x86_64.rpm                      2.3 MB/s |  23 MB     00:09
(6/10): kernel-debug-core-4.8.15-300.fc25.x86_64.rpm                         1.1 MB/s |  21 MB     00:18
(7/10): kernel-debug-modules-extra-4.8.15-300.fc25.x86_64.rpm                1.1 MB/s | 2.3 MB     00:02
(8/10): kernel-headers-4.8.15-300.fc25.x86_64.rpm                            2.6 MB/s | 1.1 MB     00:00
(9/10): kernel-debug-devel-4.8.15-300.fc25.x86_64.rpm                        1.1 MB/s |  11 MB     00:09
(10/10): kernel-devel-4.8.15-300.fc25.x86_64.rpm                             2.0 MB/s |  11 MB     00:05
Total        4.3 MB/s | 111 MB     00:25
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
  Installing  : kernel-debug-core-4.8.15-300.fc25.x86_64                                                1/11
  Installing  : kernel-debug-modules-4.8.15-300.fc25.x86_64                                             2/11
  Installing  : kernel-core-4.8.15-300.fc25.x86_64                                                      3/11
  Installing  : kernel-modules-4.8.15-300.fc25.x86_64                                                   4/11
  Installing  : kernel-4.8.15-300.fc25.x86_64                                                           5/11
  Installing  : kernel-debug-4.8.15-300.fc25.x86_64                                                     6/11
  Installing  : kernel-debug-modules-extra-4.8.15-300.fc25.x86_64                                       7/11
  Upgrading   : kernel-headers-4.8.15-300.fc25.x86_64                                                   8/11
  Installing  : kernel-devel-4.8.15-300.fc25.x86_64                                                     9/11
  Installing  : kernel-debug-devel-4.8.15-300.fc25.x86_64                                              10/11
  Cleanup     : kernel-headers-4.8.14-300.fc25.x86_64                                                  11/11
  Verifying   : kernel-4.8.15-300.fc25.x86_64                                                           1/11
  Verifying   : kernel-core-4.8.15-300.fc25.x86_64                                                      2/11
  Verifying   : kernel-modules-4.8.15-300.fc25.x86_64                                                   3/11
  Verifying   : kernel-debug-4.8.15-300.fc25.x86_64                                                     4/11
  Verifying   : kernel-debug-core-4.8.15-300.fc25.x86_64                                                5/11
  Verifying   : kernel-debug-modules-4.8.15-300.fc25.x86_64                                             6/11
  Verifying   : kernel-debug-devel-4.8.15-300.fc25.x86_64                                               7/11
  Verifying   : kernel-debug-modules-extra-4.8.15-300.fc25.x86_64                                       8/11
  Verifying   : kernel-devel-4.8.15-300.fc25.x86_64                                                     9/11
  Verifying   : kernel-headers-4.8.15-300.fc25.x86_64                                                  10/11
  Verifying   : kernel-headers-4.8.14-300.fc25.x86_64                                                  11/11
Installed:
  kernel.x86_64 4.8.15-300.fc25                            kernel-core.x86_64 4.8.15-300.fc25
  kernel-debug.x86_64 4.8.15-300.fc25                      kernel-debug-core.x86_64 4.8.15-300.fc25
  kernel-debug-devel.x86_64 4.8.15-300.fc25                kernel-debug-modules.x86_64 4.8.15-300.fc25
  kernel-debug-modules-extra.x86_64 4.8.15-300.fc25        kernel-devel.x86_64 4.8.15-300.fc25
  kernel-modules.x86_64 4.8.15-300.fc25
Upgraded:
  kernel-headers.x86_64 4.8.15-300.fc25
Complete!
[root@localhost ~]#
Don't forget the additional step (might be required). If necessary, to rebuild Nvidia driver:
http://www.forums.fedoraforum.org/sh...5&postcount=14
Good Luck, let us know!
_nobody_
Old 24th December 2016, 07:45 AM
hvniekerk Offline
From the installer log:
-> Installing DKMS kernel module:
ERROR: Failed to run `/sbin/dkms build -m nvidia -v 375.26 -k 4.8.14-300.fc25.x86_64`: Error! echo
Your kernel headers for kernel 4.8.14-300.fc25.x86_64 cannot be found at
/lib/modules/4.8.14-300.fc25.x86_64/build or /lib/modules/4.8.14-300.fc25.x86_64/source.
-> error.
ERROR: Failed to install the kernel module through DKMS. No kernel module was installed; please try installing again without DKMS, or check the DKMS logs for more information.
However:
rpm -qa | grep kernel-headers
$ rpm -qa | grep kernel-modules
kernel-modules-extra-4.8.13-300.fc25.x86_64
kernel-modules-4.8.13-300.fc25.x86_64
kernel-modules-extra-4.8.15-300.fc25.x86_64
kernel-modules-extra-4.8.14-300.fc25.x86_64
kernel-modules-4.8.14-300.fc25.x86_64
Checking directories:
$ ls /lib/modules/4.8.14-300.fc25.x86_64/build
[huub@Klerksdorp ~]$ ls /lib/modules/4.8.14-300.fc25.x86_64/source
[huub@Klerksdorp ~]$ cd /lib/modules/4.8.14-300.fc25.x86_64/source
bash: cd: /lib/modules/4.8.14-300.fc25.x86_64/source: No such file or directory
[huub@Klerksdorp ~]$ ls /lib/modules/4.8.14-300.fc25.x86_64/build
[huub@Klerksdorp ~]$ ls /lib/modules/4.8.15-300.fc25.x86_64/build
[huub@Klerksdorp ~]$ cd /lib/modules/4.8.14-300.fc25.x86_64/build
bash: cd: /lib/modules/4.8.14-300.fc25.x86_64/build: No such file or directory
Finally:
$ dkms status
nvidia, 375.26: added
So what's going wrong? I guess I should clean up the kernel modules first? And what about the "No such file or directory" ?
Old 24th December 2016, 09:01 AM
nobody Offline
Arrow Re: F25: nVidia M2000M kmod driver
You have to have kernel development packages installed:
[intel@localhost ~]$ rpm -q kernel
kernel-4.8.13-300.fc25.x86_64
kernel-4.8.14-300.fc25.x86_64
[intel@localhost ~]$ rpm -q kernel-devel
kernel-devel-4.8.13-300.fc25.x86_64
kernel-devel-4.8.14-300.fc25.x86_64
[intel@localhost ~]$ dnf list installed | grep kernel
abrt-addon-kerneloops.x86_64 2.9.0-1.fc25 @fedora
kernel.x86_64 4.8.13-300.fc25 @updates
kernel.x86_64 4.8.14-300.fc25 @updates
kernel.x86_64 4.8.15-300.fc25 @updates
kernel-core.x86_64 4.8.13-300.fc25 @updates
kernel-core.x86_64 4.8.14-300.fc25 @updates
kernel-core.x86_64 4.8.15-300.fc25 @updates
kernel-debug.x86_64 4.8.13-300.fc25 @updates
kernel-debug.x86_64 4.8.14-300.fc25 @updates
kernel-debug.x86_64 4.8.15-300.fc25 @updates
kernel-debug-core.x86_64 4.8.13-300.fc25 @updates
kernel-debug-core.x86_64 4.8.14-300.fc25 @updates
kernel-debug-core.x86_64 4.8.15-300.fc25 @updates
kernel-debug-devel.x86_64 4.8.13-300.fc25 @updates
kernel-debug-devel.x86_64 4.8.14-300.fc25 @updates
kernel-debug-devel.x86_64 4.8.15-300.fc25 @updates
kernel-debug-modules.x86_64 4.8.13-300.fc25 @updates
kernel-debug-modules.x86_64 4.8.14-300.fc25 @updates
kernel-debug-modules.x86_64 4.8.15-300.fc25 @updates
kernel-debug-modules-extra.x86_64 4.8.13-300.fc25 @updates
kernel-debug-modules-extra.x86_64 4.8.14-300.fc25 @updates
kernel-debug-modules-extra.x86_64 4.8.15-300.fc25 @updates
kernel-devel.x86_64 4.8.13-300.fc25 @updates
kernel-devel.x86_64 4.8.14-300.fc25 @updates
kernel-devel.x86_64 4.8.15-300.fc25 @updates
kernel-headers.x86_64 4.8.15-300.fc25 @updates
kernel-modules.x86_64 4.8.13-300.fc25 @updates
kernel-modules.x86_64 4.8.14-300.fc25 @updates
kernel-modules.x86_64 4.8.15-300.fc25 @updates
libreport-plugin-kerneloops.x86_64 2.8.0-1.fc25 @fedora
Packages in RED! At least for the latest kernel: 4.8.15-300.fc25.
_nobody_
driver, f25, kmod, m2000m, nvidia
Nvidia Driver (kmod-nvidia or akmod-nvidia) not working on GT555M soumen Hardware & Laptops 3 29th January 2012 01:28 PM
kmod nvidia driver quad-sli Smokemare Hardware & Laptops 6 9th March 2008 06:53 PM
NV driver and kmod-nvidia coyoteboy Using Fedora 2 2nd September 2007 01:28 PM
FC6 And Kmod-nvidia-legacy Driver oll EOL (End Of Life) Versions 3 1st December 2006 11:54 AM
Is it necessary to install kmod-nvidia driver? shawnrgr Using Fedora 3 11th April 2006 01:33 PM
Current GMT-time: 06:30 (Monday, 27-03-2017)
