  #61
Old 13th March 2017, 07:11 AM
hvniekerk Offline
Re: F25: nVidia M2000M kmod driver
Originally Posted by nobody View Post
I almost forgot about this thread... Good that you solved this problem.
I'm very glad too
Could you, please, do me a favor? Could you post for me your Xorg.0.log file for inspection, AFTER adding nouveau.modeset=0 option in kernel command line (BEFORE de-installing proprietary Nvidia driver)?
_nobody_
See attachment
Old 13th March 2017, 01:22 PM
bobx001 Offline
Originally Posted by hvniekerk View Post
OK, I've found out that it's not any driver that bothers me. It's Wayland which I want to disable, but can't found out how. All info refers to /etc/gdm, however, I'm running LXDE, not Gnome. So can anyone tell me how to do it in LXDE so I use Xorg?
dnf install lxdm
systemctl disable gdm.service
systemctl enable lxdm.service
at least that will give you a clean login screen.
EDIT: also the proper way to disable nouveau, and get the nvidia drivers working is:
1. make sure you have the nvidia drivers installed (say from rpmfusion, or proprietary)
2. edit /etc/default/grub
and make sure you have this:
GRUB_CMDLINE_LINUX="rhgb quiet nouveau.modeset=0 rd.driver.blacklist=nouveau"
then execute: grub2-mkconfig -o /boot/grub2/grub
Once you reboot, if you chose the akmod / dkms way for the modules, you will notice that the login screen takes a while to load, that's cuz the system is compiling the kmod. Don't worry , this will only happen once in a blue moon.
Old 13th March 2017, 09:23 PM
nobody Offline
windows_98_nt_2000chrome
Question Re: F25: nVidia M2000M kmod driver
See attachment
Basically, this is what I see from your Xorg.0.log:
[ 7.862] (II) LoadModule: "glx"
[ 7.864] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 7.880] (II) Module glx: vendor="X.Org Foundation"
[ 7.880] compiled for 1.19.1, module version = 1.0.0
[ 7.880] ABI class: X.Org Server Extension, version 10.0
[ 7.880] (==) Matched intel as autoconfigured driver 0
[ 7.880] (==) Matched intel as autoconfigured driver 1
[ 7.880] (==) Matched modesetting as autoconfigured driver 2
[ 7.880] (==) Matched fbdev as autoconfigured driver 3
[ 7.880] (==) Matched vesa as autoconfigured driver 4
[ 7.880] (==) Assigned the driver to the xf86ConfigLayout
[ 7.880] (II) LoadModule: "intel"
[ 7.881] (II) Loading /usr/lib64/xorg/modules/drivers/intel_drv.so
[ 7.887] (II) Module intel: vendor="X.Org Foundation"
[ 7.887] compiled for 1.18.99.901, module version = 2.99.917
[ 7.887] Module class: X.Org Video Driver
[ 7.887] ABI class: X.Org Video Driver, version 23.0
[ 7.887] (II) LoadModule: "modesetting"
[ 7.887] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 7.888] (II) Module modesetting: vendor="X.Org Foundation"
[ 7.888] compiled for 1.19.1, module version = 1.19.1
[ 7.888] Module class: X.Org Video Driver
[ 7.888] ABI class: X.Org Video Driver, version 23.0
[ 7.888] (II) LoadModule: "fbdev"
[ 7.888] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[ 7.888] (II) Module fbdev: vendor="X.Org Foundation"
[ 7.888] compiled for 1.18.99.901, module version = 0.4.3
[ 7.888] (II) LoadModule: "vesa"
[ 7.888] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[ 7.889] (II) Module vesa: vendor="X.Org Foundation"
[ 7.889] compiled for 1.18.99.901, module version = 2.3.2
[ 7.889] Module class: X.Org Video Driver
[ 7.889] ABI class: X.Org Video Driver, version 23.0
[ 7.889] (II) intel: Driver for Intel(R) Integrated Graphics
In other words, you successfully blacklisted Nouveau with this option in kernel command line: nouveau.modeset=0. I also do not see your proprietary Nvidia driver, it does not show anywhere. And this is #1 Mystery here. Why?
I see that the only HW working, and giving to you full HD: 1920x1080 is nothing more than INTEL Integrated GFX Driver on INTEL Integrated GFX HW, which MUST have by design Kernel ModeSetting (KMS):
The Intel kernel module should load fine automatically on system boot.
If it does not happen, then: Make sure you do not have nomodeset or vga= as a kernel parameter, since Intel requires kernel mode-setting.
Also, check that you have not disabled Intel by using any modprobe blacklisting within /etc/modprobe.d/ or /usr/lib/modprobe.d/.
Enable early KMS
Kernel mode setting (KMS) is supported by Intel chipsets that use the i915 DRM driver and is mandatory and enabled by default.
Refer to Kernel mode setting#Early KMS start for instructions on how to enable KMS as soon as possible at the boot process.
The #2 Mystery here is how blacklisted Nouveau, reinstalled, enabled full HD, since in your latest log I do not see any trace of Nouveau (which is very correct, should not be there, anyway)???
It should work as full HD (1920x1080) even if you de-install both Nvidia proprietary and Nouveau (in other words, ONLY INTEL Integrated GFX HW will be used, as, my best guess, is solely used now)?!
_nobody_
I am nobody, and nobody is perfect, therefore I am perfect!
driver, f25, kmod, m2000m, nvidia
Nvidia Driver (kmod-nvidia or akmod-nvidia) not working on GT555M soumen Hardware & Laptops 3 29th January 2012 01:28 PM
kmod nvidia driver quad-sli Smokemare Hardware & Laptops 6 9th March 2008 06:53 PM
NV driver and kmod-nvidia coyoteboy Using Fedora 2 2nd September 2007 01:28 PM
FC6 And Kmod-nvidia-legacy Driver oll EOL (End Of Life) Versions 3 1st December 2006 11:54 AM
Is it necessary to install kmod-nvidia driver? shawnrgr Using Fedora 3 11th April 2006 01:33 PM
Current GMT-time: 06:33 (Monday, 27-03-2017)
