Old 17th March 2017, 06:02 AM
ocratato Online
Re: Programming Challenge - list prime numbers
I knew about the extra 9 in bob's solution.
The error concerns the range, and for small limits there is an off by one error (which I have now fixed).
I edited bob's solution to remove the additional book-keeping - it made no discernible difference.
Has anyone seriously considered that it might be turtles all the way down?
That's very old fashioned thinking.
The current model is that it's holographic nested virtualities of turtles, all the way down.
Old 17th March 2017, 06:16 AM
RupertPupkin Offline
Your solution now no longer lists 9 as a prime number, but it still doesn't list 2 as a prime, and it still doesn't go up to the number you pass in. Those are easy things to fix.
OS: Fedora 25 x86_64 | Machine: HP Pavilion a6130n | CPU: AMD 64 X2 Dual-Core 5000+ 2.6GHz | RAM: 7GB PC5300 DDR2 | Disk: 400GB SATA | Video: ATI Radeon HD 4350 512MB | Sound: Realtek ALC888S | Ethernet: Realtek RTL8201N
Old 17th March 2017, 06:35 AM
hiGuys Offline
Originally Posted by RupertPupkin View Post
I think Octave is definitely worth installing. It's basically a free Matlab clone. But there are alternatives with smaller footprints.
IDL is one such alternative. Here's an IDL one-liner to list the first 10,000 primes (using GDL, a free GNU implementation of IDL, which is in the Fedora repos: dnf install gdl):
$ gdl -q -e 'print, primes(10000)'
Thank you!
Mind the gap.
Old 17th March 2017, 06:45 AM
hiGuys Offline
Takes just under 5 seconds to get the first 1 million primes, and just over 2 minutes to get the first 10 million primes:
$ time java getPrimes 1000000 > primes.log
real    0m4.912s
user    0m4.141s
sys     0m0.859s
$ time java getPrimes 10000000 > primes.log
real    2m8.225s
user    1m57.553s
sys     0m8.833s
Those are nice times. I like my tidy python scripts, but they sure can't compete in the big leagues when it comes to performance.
Mind the gap.
Old 17th March 2017, 07:05 AM
ocratato Online
Done. I've edited the original post.
[brenton@acer primes]$ time ./primes3 1000000 > primes3.dat
real	0m0.022s
user	0m0.019s
sys	0m0.003s
[brenton@acer primes]$ time ./primes3 1000000000 > primes3.dat
real	0m19.494s
user	0m19.018s
sys	0m0.486s
[brenton@acer primes]$ ./primes3 29
Calculating primes up to: 29
3
5
7
11
13
17
19
23
29
Old 17th March 2017, 04:21 PM
lsatenstein Offline
Exclamation Re: Programming Challenge - list prime numbers
In fact, I just compiled and ran your program, and it doesn't quite do what it says:
$ ./getPrimes 11
Calculating primes up to: 11
3
5
7
9
So not only is the non-prime number 9 listed, but 11 is missing (so that it's not "up to" 11), and even 2 is missing!
Maybe you should do a little research before writing code, and not blindly copy code from Wikipedia.
Edit: To be fair, bobx001's program also wrongly lists 9 as a prime number and makes the same mistakes that yours does. His program does print out more info (like divisors), though, so the time comparisons are kind of apples to oranges.
[leslie@F26 tmp]$ ./getPrimes 5
Calculating primes up to: 5
3
4
Calculating primes up to: 12
3
5
7
9
11
Old 17th March 2017, 05:10 PM
bobx001 Offline
The idea is to see the code, not only the results, that way we all learn.
Old 17th March 2017, 06:16 PM
bobx001 Offline
Here is a more interesting version, made for a 4 core, or better, a dual cpu machine,
which:
1. does not use the greeks
2. forks out into 4 children (we could also make this 2+2, for dual-core boxes)
3. stores the calculated primes into 4 distinct "interleaves" in the same shared memory segment
4. properly finds 9 as a non-prime (the >>2 was replaced)
5. creates separated logs, and also lists all the dividers found for the other numbers
6. does not use semaphores as mutex since we are writing distinct memory locations for each child process
to get the complete sorted list of primes I will just add a small qsort at the end, or simply merge the outputs in a small easy loop, into a file. Will do this next to see the final list.
#include	<stdlib.h>
#include	<stdio.h>
#include	<unistd.h>
#include	<time.h>
#include	<sys/types.h>
#include	<sys/ipc.h>
#include	<sys/shm.h>
#define LRS(a, b, c)    ((a >> b) & c)
#define	SHM_KEY_AUX		325000100
#define	SHM_KEY_STORAGE		325000101
#define	AUX_SIZE		2048
#define	PRIMES_STORAGE_SIZE	8000000 /* 8 million bytes => storage for 1 million primes @64bit */
/* AUX format @offsets:
	+0 total iterations
	+1 total primes found -> indicates offset on storage segment
	+2 start time
	+3 end time 1's
	+4 end time 3's
	+5 end time 7's
	+6 end time 9's
	+7 total primes found ending in 1
	+8 total primes found ending in 3
	+9 total primes found ending in 7
	+10 total primes found ending in 9
	+11 total iterations for primes ending in 1
	+12 total iterations for primes ending in 3
	+13 total iterations for primes ending in 7
	+14 total iterations for primes ending in 9
  STORAGE format @offsets:
	@+(total_primes_found ending in 1 * 4) +0 -> the primes ending in 1
	@+(total_primes_found ending in 3 * 4) +1 -> the primes ending in 3
	@+(total_primes_found ending in 7 * 4) +2 -> the primes ending in 7
	@+(total_primes_found ending in 9 * 4) +3 -> the primes ending in 9
void attach_to_shm(VAD_AUX,VAD1)
long int	*VAD_AUX, *VAD1;
	int	opperm=0666, opperm_flags;
	int	shmid, system_active;
	int     segment_size;
	long int	ADDR, *location;
      	opperm_flags = (opperm | IPC_CREAT);
	segment_size=AUX_SIZE;
      	shmid= shmget(SHM_KEY_AUX, segment_size, opperm_flags);
	ADDR= (long int)shmat(shmid, (void *)NULL, SHM_RND);
	*VAD_AUX= (long int *)ADDR;
	segment_size=PRIMES_STORAGE_SIZE;
	shmid= shmget(SHM_KEY_STORAGE, segment_size, opperm_flags);
	*VAD1= (long int *)ADDR;
void detach_from_shm(VAD_AUX,VAD1)
	shmdt((void *)VAD_AUX);
	shmdt((void *)VAD1);
void reset_shm_variables()
	register int	i;
	long int	*VAD_AUX,*VAD1,getVAD_AUX,getVAD1,*location;
	time_t		curtime;
	FILE		*fw;
	attach_to_shm(&getVAD_AUX,&getVAD1);
	VAD_AUX=(long int *)getVAD_AUX;
	for (i=0; i< 250; i++)
		location=VAD_AUX+i;
		*location=0;
	VAD1=(long int *)getVAD1;
	time(&curtime);
	location=VAD_AUX+2; /* this is the starting time, seconds is good enough */
	*location=(long int)curtime;
	detach_from_shm(VAD_AUX,VAD1);
int	calculate(n,limit)
int	n;
register int	limit;
	char		fname[32];
	register int	i, c, d,e=1, modulo,divider_found;
	long int	primes_found=0,calculations,total_calculations=0;
	long int	numprimes_offset,iterations_offset,offset,end_time_offset,storage_offset;
	long int	*VAD_AUX,*VAD1,getVAD_AUX,getVAD1,*location,*location2,*location3;
	time_t		curtime;
	FILE		*fa;
	sprintf(fname,"output%d.txt", n);
	fa=fopen(fname, "w");
	switch(n)
		case	1:
			iterations_offset=11; storage_offset=0; numprimes_offset=7; end_time_offset=3;
			break;
		case	3:
			iterations_offset=12; storage_offset=1; numprimes_offset=8; end_time_offset=4;
			break;
		case	7:
			iterations_offset=13; storage_offset=2; numprimes_offset=9; end_time_offset=5;
			break;
		case	9:
			iterations_offset=14; storage_offset=3; numprimes_offset=10; end_time_offset=6;
			break;
		default:
			break;
	location=VAD_AUX+iterations_offset;
	location2=VAD_AUX+numprimes_offset;
	for (i=n; i< limit; i+=10)
		if ((i > 17) && e&1)
			e=2;
		d=i>>e;
		modulo=1;
		calculations=0;
		for (c=3;(c<=d) && (modulo > 0);c+=2)
			modulo=i%c;
			divider_found=c;
			calculations++;
			(*location)++;
		if (modulo)
			offset=(4*(*location2)++) + storage_offset;
			location3=VAD1+offset;
			*location3=(long int)i;
			fprintf(fa,"%lu is prime : calculations: %lu -- primes found: %lu\n", i,calculations,*location2);
		else
			fprintf(fa,"Divider found for: %lu --> %lu\n", i, divider_found);
	location=VAD_AUX+end_time_offset;
	time(&curtime);
	*location=(long int)curtime; /* end time */
	fclose(fa);
int	main(int argc,char *argv[])
	register int	i,limit;
	int		finished=0;
	long int	*VAD_AUX,*VAD1,getVAD_AUX,getVAD1,*location,*location2,*location3,*location4,offset,total_primes_found=0,total_iterations=0;
	time_t		curtime,start_time,delta_time=0;
	limit=abs(atoi(argv[1]));
	reset_shm_variables();
	if (!fork())
		calculate(1,limit);
		exit(0);
	if (!fork())
		calculate(3,limit);
		exit(0);
	if (!fork())
		calculate(7,limit);
		exit(0);
	if (!fork())
		calculate(9,limit);
		exit(0);
	while (!finished)
		location=VAD_AUX+3;
		location2=VAD_AUX+4;
		location3=VAD_AUX+5;
		location4=VAD_AUX+6;
		if ((*location != 0) && (*location2 != 0) && (*location3 != 0) && (*location4 != 0))
			finished=1;
		else
			sleep(1);
	location=VAD_AUX+2;
	start_time=*location;
	location=VAD_AUX+3;
	delta_time=*location;
	if (*location2 > delta_time)
		delta_time=*location2;
	if (*location3 > delta_time)
		delta_time=*location3;
	if (*location4 > delta_time)
		delta_time=*location4;
	location=VAD_AUX+11; total_iterations+=*location;
	location=VAD_AUX+12; total_iterations+=*location;
	location=VAD_AUX+13; total_iterations+=*location;
	location=VAD_AUX+14; total_iterations+=*location;
	location=VAD_AUX+7; total_primes_found+=*location;
	location=VAD_AUX+8; total_primes_found+=*location;
	location=VAD_AUX+9; total_primes_found+=*location;
	location=VAD_AUX+10; total_primes_found+=*location;
	location2=VAD_AUX+1;
	printf("FINISHED in %d seconds, num primes found: %lu , total calcs: %lu\n", delta_time-start_time,total_primes_found,total_iterations);
./primes_multi 1000000
FINISHED in 18 seconds, num primes found: 78497 , total calcs: 4701845834
I also still have the offending 5 on the inner loop of dividers, but I'll eventually get rid of that too.
Old 18th March 2017, 04:44 AM
Here's an example in Fortran, for listing the first N >= 1 primes (N is passed as a command line parameter). It uses some features of Fortran 2003, included with the GCC gfortran compiler (dnf install gcc-gfortran).
Save this as getPrimes.for:
logical function isPrime(m)
   integer :: m, i
   logical :: res
   res = .TRUE.
   if (m > 3) then
      if (mod(m, 3) == 0) then
         res = .FALSE.
      else
         i = 5
         do while (i*i <= m)
            if ((mod(m, i) == 0) .or. (mod(m, i+2) == 0)) then
               res = .FALSE.
               exit
            end if
            i = i + 6
         end do
      end if
   end if
   isPrime = res
end function isPrime
program getPrimes
   integer :: N, p = 3, counter = 1
   logical :: isPrime
   character(len=32) :: arg
   call get_command_argument(1, arg)
   read (arg, '(I32)') N
   print *,2
   do while (counter < N)
      if (isPrime(p)) then
         print *,p
         counter = counter + 1
      end if
      p = p + 2
   end do
   stop
end program getPrimes
Compile and run:
$ gfortran -Ofast -ffree-form -std=f2003 -o getPrimes getPrimes.for
$ ./getPrimes 11
           3
           5
           7
          11
          13
          17
          19
          23
          29
          31
Old 18th March 2017, 05:38 AM
ocratato Online
I was just messing around with my solution and discovered that about a third of the total time (for a billion limit) was spent in the printf() function at the end. If I just count the number of primes it drops from 18 seconds to 10 seconds. I guess writing 50 million numbers take a while.
So I wrote my own little print function:
inline void print_int(int val)
        static char outbuf[4096];
        static int p = 0;
        char chars[16];
        int digits = 0;
        if ( val < 0 )
                fwrite(outbuf, 1, p, stdout );
                return;
        do
                chars[digits++] = ((val % 10) + 0x30);
                val /= 10;
        } while (val && digits < 16);
        while (digits>0)
                outbuf[p++] = chars[--digits];
        outbuf[p++] = '\n';
        if ( p > 4080 )
                p = 0;
Old 18th March 2017, 09:10 AM
bobx001 Offline
Now, if we want to use the greeks, we get:
time ./primes_greeks 1000000000 > LOG
real    0m22.571s
user    0m21.980s
sys     0m0.474s
on my 2012 Vaio Z
cat /proc/cpuinfo
processor       : 0
vendor_id       : GenuineIntel
cpu family      : 6
model           : 58
model name      : Intel(R) Core(TM) i7-3520M CPU @ 2.90GHz
stepping        : 9
microcode       : 0x1c
cpu MHz         : 1269.989
And a very Q&D, not optimized version of the proggy looks like:
#include	<stdlib.h>
#include	<stdio.h>
	register int	i,c, d, e, limit;
	int		finished=0,found;
	char		*da_array;
	da_array=(char*)calloc(limit, sizeof(char));
	i=2;
	printf("%lu\n",i);
	while (!finished)
		for (c=i; c< limit; c+=i)
			da_array[c]=1;
		found=0;
		e=i+1;
		while (!found)
			if (!found)
				d=da_array[e];
				if (d == 0)
					found=1;
				else
					e++;
		printf("%lu\n",e);
		i=e;
		if (i >= limit)
			finished=1;
	free(da_array);
However, we don't get any extra science from the list, just the primes.
for a billion I am getting:
wc -l LOG
50847535 LOG
Old 18th March 2017, 12:16 PM
ocratato Online
@bobx001 - you might want to throw my print_int function into your program - it should chop about 5 seconds off the time.
I think I've found a method for doing a sieve with multiple threads.
It relies on the fact that the largest factor of numbers up to L is sqrt(L).
The idea is to divide the sieve into pages where the each page has a size of at least sqrt(L) and get the primes for the first page using the normal sieve routine. The remaining pages only need to be culled of the primes identified in the first page which is something that can be distributed over multiple threads.
If the page size fits in the L1 cache it should be quite fast.
Old 18th March 2017, 03:13 PM
bobx001 Offline
Yeah, saw that, awesome, maybe we can make it even smaller !
The multicore idea for the sieve is awesome, but I am first going the bitwise ops. array manipulation, so that we can allocate the least amount of pages for the most amount of data. I will do some timings and post my results.
Old 18th March 2017, 04:07 PM
bobx001 Offline
On my slower Desktop PC (AMD 5300 dual-core)
I just ran a comparison between bitwise and standard char array,
and I come up with this:
[bobx@nova test]$ time ./primes_greeks 1000000000 > LOG
real    0m44.222s
user    0m42.700s
sys     0m0.862s
[bobx@nova test]$ time ./primes_greeks_old 1000000000 > LOG2
real    0m44.562s
user    0m41.811s
sys     0m1.281s
rhere the code difference is as follows, here the bitwise ops version, which utilizes 1/8 the ram as the other one:
#include	<stdlib.h>
#include	<stdio.h>
	register int	i,c, d, e, f, limit;
	char		*da_array,dachar;
	da_array=(char*)calloc((limit>>3)+1, sizeof(char));
	i=2;
	printf("%lu\n",i);
	while (1)
		for (c=i; c<= limit; c+=i)
			d=c%8;
			e=c>>3;
			da_array[e]|=(1<<d);
		e=i+1;
		while (1)
			c=e>>3;
			i=e%8;
			d=LRS(da_array[c],i,1);
			if (d == 0)
				break;
			else
				e++;
		if (e >= limit)
			break;
		i=e;
		printf("%lu\n",i);
	free(da_array);
and the "old" version, with the standard char array:
#include	<stdlib.h>
#include	<stdio.h>
	char		*da_array;
	i=2;
	printf("%lu\n",i);
	while (!finished)
			da_array[c]=1;
		found=0;
		e=i+1;
		while (!found)
			if (!found)
				d=da_array[e];
				if (d == 0)
					found=1;
				else
					e++;
		printf("%lu\n",e);
		i=e;
		if (i >= limit)
			finished=1;
	free(da_array);
Old 18th March 2017, 04:17 PM
bobx001 Offline
And a small improvement optimizing the loop constraints:
real    0m43.760s
user    0m41.506s
sys     0m1.289s
with the loop looking like:
while (1)
			da_array[c]=1;
		found=0;
		e=i+1;
		while (1)
			d=da_array[e];
			if (d == 0)
				break;
			else
				e++;
		if (e >= limit)
			break;
		printf("%lu\n",e);
		i=e;
challenge, list, numbers, prime, programming
Programming Challenge: Create a list of X random numbers between Y and Z sea Programming & Packaging 6 14th December 2015 06:28 AM
A programming challenge. lsatenstein Programming & Packaging 3 4th January 2015 04:04 AM
Programming Challenge: Comparing Numbers in a String Flounder Programming & Packaging 23 10th January 2014 03:53 PM
[BASH]: Prime Numbers sea Guides & Solutions (Not For Questions) 14 21st November 2012 10:18 AM
Program to find prime numbers renkinjutsu Programming & Packaging 9 4th September 2011 07:40 AM
Current GMT-time: 06:39 (Monday, 27-03-2017)
